OMC 595 Drum Baler
JUIN
12-23-2006 09:51:52
Any good?? How heavy can make a mixed grass bale? I found one very cheap. Thanks for comments.
JMS/MN
12-23-2006 14:18:01
 Re: OMC 595 Drum Baler in reply to JUIN, 12-23-2006 09:51:52
Make sure the chamber is not twisted- when you look at it from a distance,the rolls should be perpendicular to the side frames. Everything should look square and true. Also, the 'dimples' on the rolls wear with age, and will not rotate material well when worn off. More of a problem if you want to bale difficult material like corn stalks.
