John Deere 327 Square Baler
Brad in VA
08-06-2006 18:39:14
Hello all, just had a quick question, we are looking at a 327 JD square baler.. just wanted to know what yall thought of them?? we have heard that they will not tie and the guy that has this one says it has never tied right since he bought it new from the factory... is this a common problem with them that is just a 327 or is there something that can be fixed that we dont know about? just any thoughts on the balers would be helpful. Thanks in advance
Randy Leizear
07-08-2007 03:30:04
 Re: John Deere 327 Square Baler in reply to Brad in VA, 08-06-2006 18:39:14
I want to shorten my bales and lighten them up from 60lbs. Don't have a book on it. So I could use some help
j cook (iowa)
08-07-2006 08:27:22
If the knotter in a 327 JD does not tie right, it is because it needs adjustment. Those knotters are the same knotters that every JD baler since the 14T has used---literally millions of balers. If there had been something wrong with that knotter's design, it would have been noticed for a certainty. I have a 337 and it doesn't misstie anything---ever!
Shovelman
08-07-2006 07:57:26
With regard to missing knots when switching over balls of twine, I have found that if you put a tiny dab of Gorilla Glue on each side of the knot (either a square knot of sheet bend) the baler will not miss when it changes over.
Good luck,
Scott
Shovelman
08-07-2006 08:00:53
 Re: John Deere 327 Square Baler in reply to Shovelman, 08-07-2006 07:57:26
My previous post should read "(either a square knot OR sheet bend)"
Sorry 'bout that.....
Joe in IN
08-07-2006 06:42:04
I've had a 327 for 3 years and it doesn't miss knots. As Rick said, when it changes balls of twine it might miss, I assume the operator(me) didn't tie it together right. Other than that it is a workhorse and gives zero problems. I wouldn't trade mine away.
Chick
08-06-2006 20:39:40
Someone can make it tie right. Knotters can be a pain in the butt, but all can be adjusted to work right. Sometimes it is just an adjustment, other times parts must be replaced. Good luck.
RickL
08-06-2006 19:24:15
I ran one of those for years in fact wish I would have kept it,it was excellent unit for me Only time it would miss for me was when it would switch balls sometimes and that usually wasn't its fault.simply had knots to big myself. Its still going for the fellow that bought it from me.
RickL
08-06-2006 19:24:03
Ken Macfarlane
08-08-2006 10:02:43
 Re: John Deere 327 Square Baler in reply to RickL, 08-06-2006 19:24:03
Have a JD336 that wouldn't tie when we got it. Got a manual adjusted a few things and it hasn't missed more than one bale per twine change so about one bale outta 600.
