400 planter
J Ko
01-22-2006 12:21:00
Have a 400 cyclo with 1000 pto hydraulic pump. Can I get a 540 pump that puts out enough pressure for this planter? I don't think I should use an adapter because then it might turn too slow, but I could just keep rpms up?
Allan in NE
01-22-2006 15:27:20
 Re: 400 planter in reply to J Ko, 01-22-2006 12:21:00
J Ko,
Even with the 1K pump you have to keep the revs up to get the 11 oz of pressure.
CaseIH ought to be able to get you that 540 pump. Be aware tho, it's gonna be spendy; probably $1200 'er better.
Allan
IaGary
01-23-2006 19:51:23
 Re: 400 planter in reply to Allan in NE, 01-22-2006 15:27:20
J Ko
Here in Iowa there are many 400's sitting around as junk put an ad on the classified ads to the left of this page for a used 540 pump and I think you might come up with one depending on your location. If your close or want to travel to eastern Iowa I can maybe get you one. I will open my email.
