I purchased a K2 last fall and it worked
Like a champ on my 10 acres. I started it up several times all year without problems. I began prepping it for this fall and ran into some issues on the hydraulics.
No fluid is getting to the main clutch.I can raise the head but when I release the handle it falls. I can move the auger out but it won t retract. Power steering works and I can turn on the head. Port 2 was stuck which goes to the main.
I cleaned the manifold.
Everything was put back together and still have the same issues. I did not separate the manifold. Looking for ideas? And possible a "gleaner combine repairman" who could assist in Michigan.
I did remove the hose on port 2 to the main and even when I move the rod no fluid is coming out. The poppets look ok. Could I have a pump issue?
Any help is appreciated.
