Dial-a-matic control mounting bracket dimensions
sshowman
New User
I'm almost done fitting a dial-a-matic system on my 4400. I'm just missing the bracket to mount the controller (H111374 - deere no longer sells this part). It should be easy enough to fabricate but I'd like to have the exact dimensions or at least the thickness of the material. Drill hole locations are not needed. I already have both control boxes and the mounting hardware.
I took some approximate measurements:
Length 12.5
It is bent at a 90 degree angle to bolt to the bracing. The width of the horizontal bottom of the part is about 1-1/8 where it bolts to the brace. The width of the vertical portion that the control boxes mount to is about 4-7/8. I assume a 6 wide piece of material will get it close enough to work.
The top corners of the part are nipped off at 45 degree angles to eliminate pointed corners.
The thickness with paint is 0.109 so I assume 3/32 thick steel was used.
If you need photos, please let me know.
Lon
