Upper feeder house belt on jd 4400
Hi guys I have another question for you. I need to replace the upper feeder house belt on my jd 4400. Its a variable speed feeder house. Do I just take the nut off the top and bottom that would remove the steel plate that holds the hydraulic cylinder? Sorry if this isnt that descriptive. Im not sure how else to describe it. Will anything fall apart unexpectedly? I know I have to remove the belt guide around the electromagnetic clutch. Is there anything else? Thanks for all of your help.
