I was installing a yield monitoring system on my K2 today and found the clean grain elevator chain was a little loose, i heard the chain jump some and
the chain has around an inch of play, the manual is not really clear about how tight or loose it should be, what do you guys think?? I think it needs
to be tightened up some but i'm no expert.
If anyone is interested in a yield monitoring system check out FarmTRX, its one of the more affordable systems and it easy to install and use, even
get yield maps and alot of info on the screen. The moisture sensor is extra money but i didn't get it, I can't combine corn above 22% so i didn't
need that option.
need that option.
