I recently got a JD 6620 Combine. I attached a picture of the air filter packed with Bahia Grass seeds- to give an indication of the Maintenance it has received
My question is about the Transmission and Hydrostatic Drive system fluids.
The manual says:
1) Transmission- JD API GL5 80W 90W Gear Lubricant. Capacity 11 qts.
The JD GL5 gear oil is $40 per gallon. Anything special about this? Or can I use any 80-90 wt. gear oil meeting GL5 specs.?
2) Hydrostatic Drive System- John Deere All-Weather Hydrostatic Fluid or oil meeting J21A.
The folks at the local John Deere place were a bit confused but finally said use Lo Viscosity Hy-gard.
Any suggestions for what to use welcome
Thanks!! Rich
The manual says:
Thanks!! Rich
