Biggest pull type combine with header?
dhermesc
I was going through next tech classifieds and found a old John Deere 36 with a 20' head. I had never seen anything like it before.
John Deere sold a pull type 9500 not sure of the model number. Also know of some 7721 pull types. Almost all late model pull types were more for using a pickup header. Tom
The IH axial flow pull types and the JD 7721 and 9501 were the biggest pull types made at least in NA. As already stated they were used mostly for picking swaths although you could use a small straight header on them. The 36 combine was common out here in the west.
Before we scrapped them we had a JD/Holt No 36 and a Case Q which is a Model P with a rasp bar cylinder. Anyways both combines had the same size cylinder but the separator on the 36 was much larger. Both combines had 16 headers but they looked small on the 36 and big on the Q.
