Gleaner 313 flex head
Doug Wi
should my cutter bar look like this with more flex on the ends than in the middle? has been like this since I bought it and has worked ok. Remembered to take
pictures this year and thought I would ask about it.
I assume whatever it has under there for 'springs' are adjustable? My CaseIH head has large, flat leaf springs adjustable with a long threaded bolt on the back of the header.
Looks like mine, I don't think it's a problem, as long as the cutterbar follows the ground contour when you lower the head. You could adjust the spring tension on the snouts to bring them up a little if desired.
Ben
