(quoted from post at 19:10:58 10/12/21) I'm looking for a simple explanation for the similarities and differences in the Massey Ferguson combines from the mid- 1960's to I guess maybe the end of the 1970's.
I want to know what models would share similar parts to my MF-300 combine (it has slant-6). The engine I can take care of, it's the other mechanical parts.
I sorta know that the 510 "looks" similar to the 300?
Its when I'm looking through parts available on-line that I'd like to know if the johnson rod from a 550 or what ever would likely work on the 300.
A chronological explanation of the timeline of when these combines were made/sold would also be informative.
Tom Carroll was the main engineer at Massey harris combines. He designed the Massey Harris 20,then the 21. He spent his entire life living everywhere.
Toward the end of his carreer, he was an expatriate for Massey in Scotland (for the Kilmarnok factory), and designed the 400 and 500 combines to be built there in 1960.
Those had ground breaking technology, like improved operator comfort, saddle tanks, hydraulic turret style auger, 2 speeds variable speed cylinder drive, tailings retresher, rotay screen for air intake on the engine, and the list goes on...
The width of the walkers, cylinder, and shoe was the same on the 400 and 500.
In USA, the Super 92 and Super 82 were sold at that time. The super 92 featured the wider walker body compared to rest of machine, and was related to the Massey Harris 21 that also shared engine under separator.
In 1963, the 410 and 510 ware released in NA, built in a brand new factory in Brantford, Ontario. In fact, North America was waiting for the new factory and new production tooling to replace the outdated massey with engine under the separator.
The 410 and 510 were improved over the Kilmarnock 400 and 500 by having the wider walkers, and the 3 screens cascade shoe. The 400 and 500 had a more conventional shoe.
The 410 and 510 were also launched in production for 1964 or 1965 in France (Marquette plant) and Kilmarnock. So 3 factories were building them at the same time, and they were big hits.
I think the 300 was introduced on the US market slightly before the 410 and 510, but I am not sure. The 300 had a specific design compared to others models of the range (410 and 510). I think not much can be swapped between a 300 and a 410, because the layout of the belts is different. 300 is simpler machine.
Interestingly, the massey 300 did not made it to Europe, but instead top mounted engine combines similar to the 35 and bigger were developped in Germany. Those Germans models design was exported to Brazil and were still made in improved version few years ago (and very successfull).
The 300 was replaced in the lineup by the 205 with a top mounted engine.
The 410 replaced the Super 92 (37 inch cylinder), and was replaced by the 540.
The 510 was a new size (45 inch cylinder), and was replaced by the 550.
It must be noted that there was a "genereation 2" of the 510 introduced around 1969 I think: In Europe, the 510 was replaced by the 520 in 1968. That combine had a longer cleaning shoe similar to the one fitted on the late US made 510s. The 520 was even replaced by the 520 "Super 2" during the mid seventies (same time the 550 was introduced in the USA), and got the same high inertia treshing cylinder than the 550.
Like the 550 is often accused of reliability issues, the 520 was never seen as as good as a combine as the 510. Build quality was an issue, but it could be that combines were built lighter than the earlier one.
I hope this is clear. Massey combines development and evolution at that time period needs to be seen globally, because there was lots of interation between Europe and NA for improving and designing combines. But as per your first question, the 300 is an orphan, parts wise.
If in doubt, you can always lookup by "parts number" on AGCO Partsbook online.
