Gleaner m combine
Looking for a quick Id on my combines carburetor. The float has a leak. I'll solder it but what carb is it? It has a chev 350 but I can't read what brand carb it is. Easy I'd or did they have several different brands? Thanks
Bob - not sure but the link works correctly on my end from the post. Here's a screen capture from the page.
I've been trying to figure this out. I can't see why the Zenith would work any better than the Rochester with a governor. Maybe the single top was the key? The Rochester was only configured with a two barrel top which worked with an air filter housing? And the Zenith single opening was what they wanted for the air pipe to fit on?
It's that Stromberg ww. Never heard of it, and getting the float out and in was a bit not fun. Gonna try and find an extra float in case my solder job didn't quite work. But it does run excellent. Thanks
