gleaner e fuel pump leak
Hello. Th gleaner E i have with a gas engine has a leaking fuel pump. It is leaking our an indentation where the screw driver is pointing in the pic. Where can I get a replacement or seal/rebuild kit (possibly NAPA?) or any possibility of replacing with a electric pump?
(quoted from post at 20:10:53 06/25/21) Hello. Th gleaner E i have with a gas engine has a leaking fuel pump. It is leaking our an indentation where the screw driver is pointing in the pic. Where can I get a replacement or seal/rebuild kit (possibly NAPA?) or any possibility of replacing with a electric pump?
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto92997.jpg>
You should be able to get a new pump through your AGCO dealer, part number 70256928.
Or bypass it and install an electric pump.
New ones that fit Massey tractors look to be a match for the Gleaner E/EIII G226 gas engine combines. The priming bail is different but they are pretty cheap. LOTS of sellers on E-bay at different prices. Here's one seller that shows lots of pics to see what you are getting. Make sure the glass bowl is on the correct side.
https://www.ebay.com/itm/171997355044?hash=item280bd75c24:g:9kAAAOSwZVhWRRFD
This post was edited by Skyhighballoon(MO) on 06/29/2021 at 01:29 pm.
