McCormick 101 Combine
Does anyone know somebody out there that has the ability to recast parts ? Or can you send me in the direction of a parts machine. New to this forum. Looks like I should of started 10+ years ago. Thanks
Here are some pictures, it will probably be easiest if you can give me a call. My number is 319-863-3136 Thanks!
The fork is a steel casting because it is welded, so I think you can repair it.
Pulley sheaves are unlikely to be Weldable or only with nickel rods, but if you are just fighting wear, you can probably have them turned to compensate belt wear and have bushings installed where they slide to run thrue. It would've a lot cheaper than to cast new ones. It wight be better to put them on a tire balancing machine before and after to avoid vibrations.
