CIH 1460 bad engine worth
mudcreek183
A friend from work son went to look at a 1460 from an estate other then the engine which must have a cracked block from what I can gather, the rest of the machine is in good shape. Machine was kept inside for all its like ,with just 1 owner, they went to check the oil and antifreeze came gushing out. Question they are asking $3500 ,I think it would be worth that much if it was parted out. TIA
(quoted from post at 16:01:50 12/30/20) How many hours? Bad engine and age would make it a $2500 combine here.
He said about 3500 Hr. and the last year the 1460's were made which would make it a 84 or 85 I believe.
707 a ton right now unless you need a parts machine then a
little more maybe or you know someone who has need of
parts and you have them sold if you had them
Lots of ways for a block to crack besides freezing. I’d think maybe a bad oil cooler or bad head gasket or cracked head
Not sure your location, but I am So. Wisconsin. I know a guy has a salvage yard full of stuff and a
number of these combines. I run a 9700 hour 1460 and am sure you could find an engine as they are
common. six o 8 two 14 38 five 2. You might need to buy that one a little cheaper.
Went look at it with him last week not a bad machine for its age very little rust,he got it $2500.He has to move it 25 or so miles,he thinks he has a friend that will be able to get it move for him in a week or so.
