urbancase
this past fall while I was running corn and had a chain break on the head, so by the time I got repaired it was getting darker and I wanted to finish the field. so I flip the lights on and it disengaged my header controls and the corn head stopped working, the rotor kept turning. I tried it 3 times and also shut it down turned the lights on then started the header and it would not turn on. has anyone had a similar problem? I need to work on this summer as I will be putting out a lot of corn this year and know I will be running at night. I was never impressed with the way caseih did there wiring in these model combines so looking for a starting point if need be I guess I will bit the bullet and spend the money for the wiring diagram.
thanks for the help.
