young tractor
Hi guys. This post might get long in order to explain everything. 2 years ago I broke the primary counter shaft. Or should I say a guy I bought it from welded it when he broke it. I had a local well known tractor mechanic fix it. The electro magnetic clutch mounts on the ladder side of the primary counter shaft. This fall it combined corn just fine until the last two unloads. I went to pull the unload lever and it wouldn?t go back to unload. I pulled the seat out and looked. It was hitting the pulleys on the back of the electro magnetic clutch. At the time I figured if I engaged the separator I would have just enough clearance. Today. I looked into it and realized that the back pulleys that are behind the electro magnetic clutch can slide back and forth, thus slide over enough to interfere with the unloading auger pulley. Is that pulley supposed to bolt up to the back of the electro magnetic clutch? What is supposed to hold it in place? I
