Re: Ih 1460 won’t move
CDN 400
02-09-2018 13:08:56
Did you check to see if the hydraulic motor on the transmission is turning when you push the lever? Pull the four mounting bolts on the flange and slide it away from the transmission and get some one to hit the hydro lever. If it turns check the splines real well and it will probably be the input shaft of the transmission stripped out. I have seen a few of them fail and just did my own last summer.
