3020G-x5 combines.
DeltaRed
In a previouse post you asked about putting a 6 row head on a 95. DONT!A 95 is a 4 row machine at best. A 6 row head is heavy. So heavy the standard lift cylinders wont even lift. If they do,the rear endisnt heavy enough to counterbalance. I run a 443 on my 95. in good(200+) corn you are in low gear.Not so much for lack of power,but there is just not enough separating capacity for 6 row.I put 105 lift cylinders on,they helped a lot.And as mentioned earlier,with that much weight,something WILL break.You can thresh a lot of corn with a 4 row head.However if you absolutely must have a 6 row,better get a 105.I just finished my corn harvest. Probably beat 180 bpa.I was in low to allow time to separate.I could only take 6 rows pre round,instead of 8 because the combine didn't have enough bin for one full round pulling 4 rows each way.Only have one truck,so placing a truck on each end wasn't an option.And I wasn't going to 'deadhead' 3/4 of the way to the truck to unload.IMHO,a 45 is a 2row;55 is a 3 row;95 is 4 row;105 is your 6 row machine.
If he wants six row that means he has a six row planter. I would go with three row narrow. Plenty of capacity and extra bin space in long rounds. If I ever change to narrow rows that is my plan. Tom
I appreciate the response. The 6 row narrow planter is already here and is in good shape. When I was a little kid we had a 45 with 3 row head. I know you can shell 4 behind a 6 row planter but there’s a lot of curves around here that makes that tough. I wouldn’t be opposed to any x5 machine in terms of size.
I started with a 45 squareback with a 313(3 row) head. At that time,I was planting 4 row. Then I 'updated' to a 6 row.Then a couple of years later I bought the 95/4 row.Now I'm back to planting 4 row.
I have to get out a manual and look, but is a 95 narrow enough for 3 rows narrow??? I know the market a 3 row wide head with a 95, but not sure about narrow.
Also, about 20 years ago, JR Hobbs wrote in green magazine about putting a 6 row row crop head on a 95. If memory serves, he had used 105 lift cylinders and perhaps some weight on the rear axle. He claimed that worked really well, but there is a lot less material in 50 bu beans vs 150 bu corn.
We put the 105 through a lot of 200 bu corn, and weighed 1/4 mile samples of up to 265 with her. With 6 rows going in, you were either in 2nd as slow as it would go, or in first. And even with a big grain tank extention, you dumped A LOT! Get on a hillside, and you really had to crawl as well. The good part was that at very slow speeds, there is very little header loss!
I would stay away from a 55. With a three row head it will be maxed out in good corn,has a small bin and small unloading auger that takes a long time to unload. I just hauled my 55 to the scrap yard yesterday. We only cut soybeans with it and a few years ago it started getting compression in the cooling system and the cylinder bars were worn as well as much of the metal was getting very thin. A friend wanted the motor and we pulled lots of parts off it and still got $312. Not bad for a machine that cost me $1000 and gave 8 years of use with no problems other than maintenance. It was hard to park it as I think it must have never sat outside as all the paint and metal were perfect. After cutting beans with the 95 I would not want to go back to the 55. Tom
