JD 4425 Combine and 653A Header?
Does anybody know if the JD 653A Header is Hookup Compatible with the JD 4425 Combine? I attach a 443 & 213 flex now. And my hydraulics went out for running the 213. I don't think you need the reel hydraulics to run the 653A Header do you?
fits right up. I first ran a 453A now 653A had a 4425. Bought a 35 with RWA ran 653A on both. You will probably need a couple wedges should already have some on one of your other heads. Tom
