Case ih 1640 headlights half working
elk1640
New User
Left 3 headlights not working on combine checked all wires and grounds still not working and the right 3 work fine. Any ideas?
How did you "check" the wires. Visual inspection doesn't mean they're ok.. get the voltage meter or test light out and you can tell where your problem is.
Do you have two switches, one one the dash and one in the overhead panel? I'm trying to remember but I had one that if you only had one switch on it would do something weird like only light up one side. You really need a test light or multi meter and start checking.
