newgenjdcollector
Having some trouble picking up the 643 cornhead I got for this combine. Suspect the pump as it should lift it. Today we checked pressure on the pump. While holding the lever it peaks around 1900 and then begins backing off slightly. Anyone know what the standby pressure should be off-hand.
Probably time to swap out this pump. Anyone know if a pump off a later model combine would interchange. I do have a pump off a parts combine but no idea if it's better or not without actually changing it to see. Any way to have one checked before going to all that trouble?
