Getting flashers on head on 9500
Mitch D
Going to get the flashers hooked up on the ends of our flex head and realized the combine, early 9500, don't have and wires for flashers in the harness along the feeder house. If you were in my shoes where would you look to tap into the combine harness to find power to send down to the head? Kinda thinking in the steering post might have the smallest harness to find the wires in....?
Is there more than one connector under the cab near the feederhouse where the feederhouse wiring harness(es) plug into the main harness, or perhaps there some extra pins not used in the connector where the harness you now have plugs in?
Not using the Dial a speed pins but the rest are, still need to find where to get a power source for the lights. Closest I found is in the grain tank by the lights up there
