I have a question about the wobble box on a John Deere 200 series grain head (220). How is the shaft coming out of the bottom of the gear case and the driving arm matched together????? Are the splines taper cut or are they straight cut????? I switched out a wobble box today from a spare head to the one I primarily use. The one I took out seems to have about 3/16 to 1/4 inch of play if measured out at the end of the arm. You can see the arm move independent from the big nut on the bottom - the wear is in the splines. I tried to tap the arm up on the shaft more thinking it would get tighter but it never moved up or tightened any. Makes me think they might be straight cut or the arm has become worn excessively??????? The one I put on is 100% tight with hardly any play in the internal parts when rolling the pulley. Looks like the one I removed might be leaking a small amount of 80-90 wt. as the top of the skid plate was covered with dirt and oil. I wonder if oil has been working into the splines and caused the splines to "work" on each other??? Last question - is there a fix to the loose shaft and drive arm I took off - robbed it off of my 216???? Thanks.
