Tractorcedric
- Location
- Garland. Utah
So I have an F2 diesel hydro that was used as a small grain combine. I want to use it for soybeans. In the operators manual it shows that two hyd lines connect the automatic header valve to the original header valve in the valve stack. The header valve section on my F2 only has one hose connection. Would I have to change out that section to put the auto header control on this combine? The section I have does have the bolt at the back to adjust out for the detent to work. Could the other line just be returned to tank? Need to find a parts machine. Thanks!
