205 corn head
need help how does the drive sprockets AN11251 and P46429H mount on the cylinder shaft? the parts book shows the corn head drive sprocket but no hub does it bolt to the inside sprocket? trying to mount on a John Deere 42 combine anyone have a picture of the drive sprockets for a corn head on a 40 or 42 John Deere combine they could share? Thanks Howard
Howard,
They use three spacers between the cylinder driven sprocket and the corn head drive sprocket that mounts them both to the cylinder shaft. Hope this helps. Tom
Howard,
Some good washers and longer bolts will work. All you need is enough room between the sprockets for clearance between the chains.
