Time to get the combine ready for wheat harvest which is about 2 weeks away. Got it running but would not move and had no hydraulic functions. Shut it down, checked wiring and hydraulics, found the reservoir empty. The combine had a very slow leak from the hydro input block just behind the drive pulley last year, and has apparently lost all the hydro fluid from this leak...where the hydro control cable goes into the hydrostatic system. No large amount of oil apparent, so it must have evaporated as fast as it leaked over the winter. Parts manual does not give a real clear breakdown of the input control where it goes into the block. Is there anything specific I should be aware of before replacing a leaking oil seal or other ring? Thanks, Ben
