Case combine 188 engine
Will I am pulling the engine out . A friend told me that he herd that there are hollow bolts in the oil system, head bolts that if they are not put back in the right spot you do not get oiling . Never heard of this one before. Any one ran into this before.
The only ones I know of are the two studs that are drilled for rocker arm studs, and sometimes there's a drilled bolt behind the water pump.
