4 row will be fine maybe 6 row. 15 acre feild is huge for us Transporting will be an issue also Didn't know about side hill and hillside either Hillside is probably what I need How steep will a side hill like yours level up on(reply to post at 19:02:32 12/17/16)
(quoted from post at 21:24:18 12/17/16) We had some in our part of the country, JD 6600 hillside I believe tilted 18 degrees and the sidehill was up to 45 degrees.
(quoted from post at 23:28:56 12/19/16) I would just go with a JD 6620 sidehill. YOU can harvest steeper ground just like you can harvest hill with a level land machine. With the JD 6620 you can easily switch headers and do corn/wheat/soybeans. The hillside machines would work well on wheat but not so well on soybeans as they hillside headers did not have floating cutter bars or automatic header height control. I harvest hill steeper than 18 degree OK.
Here is a picture: The field is in hay in the picture but I rotate it into corn and beans too.
