IH 815/ 915 combine
jm.
Location
Dover TN
LONG SHOT but here is my problem for an IH 345 v8 gas engine I need a flywheel that is not like that found in a truck. I need a way to fasten a tail shaft. On the gas 15 series combine that was not a hydro.. What was on the end of the engine.. A tail shaft with multi grove pulley or a clutch and pressure plate? Hope this question makes sense to some one that knows. I am making a power unit out of a scout engine which is half the v8 engine but does have the same flywheel and bell housing
Dad had a 815 gas and I thought it had a over-center clutch to engage the machine on the flywheel end. Shaft ran straight thru to drive the lower pulleys for the traction drive.
O K that was what I was kinda thinking also. Want help me but it was worth asking.. May have to look at the hydro flywheel and see what they used but I was thinking the hydro sat at a 90 degree angel and the shaft drove the separator like you are talking about.. Anyway thanks for the reply.
