MF 750 getting bean stubble under first walker on left side?
BryanG
Finished beans an i c on the left side the first an seconed straw walkers their is bean stubble packed tight between the walker an shaker pan. Every thing is working right an that walker looks the same as the others. how is it getting under?? Thanks for any help!!
Perhaps the pan is rusty in that area, or maybe even cracked or brokenm, or something is stuck there (dead rat?) making the pan ineffective in that area of "kicking" material forward.
My 750 will do that if I get some wet material into it. I use a long rod to push it forward and after several times it seems to quit sticking until I get some more wet material where I start the process over. Any rust will make it worse, plenty of dry material will scour the rust smooth and the problem goes away again.
