Dave H (MI)
Wont retract after unloading. Went out just fine but not even trying to retract. I put a rope out on the end and gave it a couple of tugs in case it was stuck, but that is not the problem. I know there is a two wire limiter switch that it pushes in when fully in the cradle that stops it...switch moves freely, is in position, and I have no idea how it works exactly for checking voltages. Suspect there must be continuity to both sides when auger is extended and lever is operated to make it retract??? What about other sources of trouble? Any suggestions? Appreciate any help!
