Hello,
Two years ago I purchased a used John Deere 3300 Combine from a retiring farmer. I found a serial number:
101064H
Can anyone tell me the year of manufacture?
Anything else I should know?
It's a gas model and I've used it for the past two years, but this year I shut if off to eat supper and now it seem to have a starter problem.
I've put in a new battery, fuel pump comes on, it clicks, but then goes dead, fuel pump goes off and light goes out. If I wait a few minutes I can repeat. If I try to start right away again it won't do anything.
I'm thinking neutral safety switch or Starter gone bad?
I've checked voltage with multimeter and it shows 12.4-14.4, if I hook up jumper cables from my pickup. And then voltage drops to nothing after I try to start. If I wait a few minutes, voltage comes back.
Can you verify the correct starter motor part number?
When I check JD parts catalog there are 9 possibilities:
RE19187
RE62916
AR91813
TY6706
RE50095
SE501400
SE501428
AT18025
SE501436
101064H
RE19187
RE62916
AR91813
TY6706
RE50095
SE501400
SE501428
AT18025
SE501436
