Last night the sensor for the hydro pressure started leaking or I should say spraying oil. The oil is coming out around the connections so it appears to cracked the sensor. First question is what could of caused this? And I can not find the part on parts advisor so I am sure the dealer will be stumped to.
The sensor is located in a block that also has a small reservoir tank bolted to it. Can anyone help with a part number? I will try to post a pick. I found a plug that fit in place of sensor so I could run but want to get it replaced.
