1460 in green stem beans help asap!
In green stem beans I cannot get them to exit the rear of the combine. They just want to set on the rear pan behind the sieves. And if I do not clean them off in time they will stop the spreaders and smoke the drive belt. Background, Rotor at 650 rpm, concaves set at 4 1/2, wind at 900 rpm. I even installed a sickle section grate right behind concaves to help break them up. I have the rotor at 650 because I got a pigweed issue this year. What am I missing? Thanks in advance for the help.
You must have one with a stationary pan. Some shook back and forth to get the material to fall off. Maybe it can be swapped for a shaking pan from a salvage yard combine.
I have the same issue with my 1440. Mine side off the pan before the spreader gets plugged. It just looks like I have straw bales laying around when I get done.
Had the same problem, had to hire a big cat combine. And even then it didnt spread to good out of back of combine.
