steveinohio
My JD 4400 upon looking at the unload auger tube I noticed the head of the pin fastener is broken off. (Part # H78180, no longer available). I tried pounding the pin out from the top but will not budge. I'm soaking it in PB blaster hoping it will come loose. What will I need to do to remove it? Apply some heat? Could it be drilled out from the top so far and insert a bolt to hold the top part in place? I've removed these pins before but never had them stuck like this one. I do not have acetylyne torch. When removed I can find something that will suffice. Any assistance is always appreciated.
