Feeder House won't come on!
brian s r
New User
I have a IH 1688 combine that when I put it away last season worked just fine got it out to get ready this season and the feeder house will not come on! anyone run in to this problem before? I think its just a relay but don't know which one it can be, No diagram.. Thanks in advance !
Get out the VOM...see if you have power at the magnet on the clutch. If you do, problem is at magnet or the clutch. If no problem, check for continuity in the wiring from the switch that activates the clutch. Mice interrupt continuity- most common. Or check from the front end, going back. No diagram, no idea where the circuitry starts?
