notjustair
I am replacing the bin fill auger on the 9500. Both the extension and the bottom section had about half of the flighting worn off.
I went to Deere and got the parts some time ago. When I went to assemble it there were a couple of parts present that I didn't have on mine when I look it apart. There was a weird worn spot though, so I think they likely wore so much they came off. I spent an hour with about three service techs and the manager at the dealership and NONE of their diagrams are detailed enough to tell
On the bottom shaft at the top end what is the parts order? From what I can gather from the fit I believe there should be a large convex washer, a felt ring with a rubber ring around the edge, then the carrier bearing, then the upper drive, then the nut. Does this sound right? The large washer, felt, and rubber rings are the pieces they can't find in a parts diagram. They fit perfectly and fill up the sloppy space on the shaft. I can't imagine I would have thrown these random parts into that bag if they weren't supposed to be there.
Anyone done these augers on a 9500?
