F2 Variable Speed hydraulic leak
I've done a search, but not found anything. Must not be using the correct search terms.
Don't know just exactly what's leaking, but it's the small hose or seals on that variable speed sheave assembly. I'm not finding the correct page on the on-line parts book either.
What might be leaking there?
It's an easy fix. It just happened to dads F2 running wheat. Inside the pully you can take out the variable speed cylinder. It just screws out and you can take it in the garage and take it apart. Kind of reminds you of a wheel cylinder inside with a couple of washers and plunger and springs. There is a rubber seal in there that looks like a wheel cylinder seal and it will have a hole in it. The Agco Gleaner dealer can print off a page for you to get it all back together and they have parts in stock. We got our parts at Card Brothers in Chesaning Mi. Was a really easy fix.
you can fix it with a water faucet o ring set,. that's how I fixt mine onmy gleaner f ,, amazingly simple fix ,,
