42 JD separator belt
I posted earlier about the separator belt part #h27956h 1.5 in wide 109 in long. I can't find anywhere tried Jay Dee Belts and others. Dose anyone have any suggestions.any help would be appreciated.
Cant believe JayDee cant match your belt.Is it the genuine OEM JD part number? Did you give em the measurmants? I have never known them to fail me. I got all the belts for my 45,55 and 95 from them.However,they did have a computer mix up once.
Yes I did the only thing they had close was 3 in longer. I did get all the other belts from them. Do you think that might work? Now I use about half the tightneright.
Put it on and try it. 3" total length will only move the adjuster about an inch and half. Is this a flat,or Veebelt? double belt.Not familiar how the 42 is set up.
