Update on 105 variable speed
tomstractorsandtoys
I posted below about trouble with my 105 combine. Today we put new bushings and seals in the center pulley and that took out all side to side play. Top belt is still not quite as tight as the bottom but much better. I wonder if my rubber motor mounts could be soft with age maybe letting the engine set a little lower? I think it will work good now,but I might replace motor mounts or just add some shims under the engine. Thanks for all the replies. Tom
