tomstractorsandtoys
Started to cut rye today with the 105. Cut one bin full as it is hardly fit. We just replaced both the variable speed drive belts with new ones from Jay Dee belts. The bottom belt is overtight and the top one is hardly tight enough. I made one round then retighten them and now after another round the top one is to loose again. I had problems last year and tore two used belts. I have 40 acres to cut and do not want to ruin another set of drive belts. We took the varable pulley loose and made sure the center pulley is free to move back and forth and lubed it as well. I adjusted the cyclinder end that controls the variable speed and thought that helped but now my belts are loose again. The top belt is longer than the bottom one and we doubled checked all part numbers to make sure we the right belts.The previous owner said he had some problems as well but I thought is was just old worn and stretched belts. Any ideas? We had six inches of rain last week and it is to start again wed night for three more days. Thanks Tom
