lee little
Thanks to everyone that has helped me so far. With the help you guys provided I finally got my $600 K to combine oats satisfactorily. Got her set up and started about 10:30 this morning. Made a couple rounds around the field then made some passes through the middle. I was tickled pink with its performance and thinking about telling you guys how well everything went. Then reality hit.... at about 2/3 of a bin full I heard a slip clutch kick in. It was on the right rear and I think went to the elevator that puts grain in the bin. I opened the bottom of the elevator and got 3 buckets of oats out of it. I then pulled the panel at the elevator top and found the chain thrown to the auger that carries grain into the bin from the elevator. I thought that would be why the elevator slipped the clutch. Started back up and threw the eccentric drive chain[located on the left side]. Put it back on and now none of the chains on the seperator run. Went back to right side and tightened what I thought was a slip clutch on the pulley that the countershaft drive belt and fan belt go on. No results. I can turn this shaft with a wrencn on the nut on that pulley and the chains and seperator move. Is there a slip clutch on this pulley? Does anyone have an exploded diagram of it because I cant find one in the operators manual. Thanks for any help/suggestions. Lee
