IH 1440 shifter
MikeinKy
I have a IH 1440 combine that after sitting this winter was stuck in gear. I started some diagnosis and the cable is stuck. I have it off and it is really stuck. Any ideas, or do I need a new one. With the cable off, I can shift it by hand.
It's almost as cheap to buy another combine. That cable is $243.00 I guess that is what I will end up doing.
Had similar with 3020 3 ph cable- capped a 3/4 inch pipe, put the cable in and filled pipe with PB Blaster, let soak a few days. Spin/push/pull cable with elec drill.
