JD 7720 Low Speed Shaft Monitor
gostate
What am I missing? Straw walker warning light will not go off at operating speed. Sensor had a crack in it so I replaced it. Still light will not go off. Put that sensor on another shaft and it works fine. Have switched magnet on shaft. Connect wire in wiring harness to ground and then light will go out. Any suggestions?
Could it be a bad wire? Seems like if you ground it and it stops it should work. I had a mouse get into my 7720 and wreak havoc on wiring.
