White 8900 Combine Hydraulic Pump
Jeremy L
I am looking for a new or remanufactured hydraulic pump for a White 8900 combine. I believe it is a webster pump. Agco says the pump and basically all parts other than the seal kit are discontinued. Is their anyone who may have a replacement pump or who still fixes these older pumps?
Thanks in advance for your assistance.
this may or may not help,, get the White part # and type it into google, I have found many things this way and I found a nos transmission lube pump for my 1470 CASE last year,,, very possible one is sitting some where,, I also had a hyd shop do a search for one,, they found the same ones on line I did
cnt
The combine will hardly lift the corn header. It is very very slow, when you lift it moves up a bit then stops and then if you let off on the lever and pull it again it will go up a bit more and than stop again.
The cylinders on the header have been rebuilt and hold even when sitting for long periods of time turned off so I don't think the issue is the cylinders or the valve. I believe the pump is original and it is likely just wore in the housing.
spallinger's in archbold ohio used to have a lot of white combines for salvage maybe try them or gene's recycling in attica ohio I know he had a few 8900's or any salvage yards near you.
A cessna pump from an MF750 to 860 seems to be very similar, with same priority. You can get them everywhere, new or used.
The pump part number from my 8900 parts book is 1554883. There's a major seal kit listed, p/n 2727677 and a backplate repair kit p/n 2727687. Unfortunately neither the parts book nor owner's manual says who made the pump.
I would think a good repair shop should be able to overhaul your pump. You don't give your location but here in Sask Hydratec in Regina does a lot of this kind of work.
The parts depot lists the 2727677 seal kit as being available in the Wisconsin warehouse, have to call a dealer for the price.
Flint hyd. 901-794-4884 they build pumps just had a ford pump made by them and was just over half what the dealers wanted perfect fit
