Windrow Pickup for IH 82 Combine
Kerwin
Anyone know if a windrow pickup from an IH 80 pull-type combine would work on an 82 combine? I know these are similar machines. I'd like to find one to fit my 82 combine.
How about from a 76? Or is the front end completely different from an 80 and 82 because of the canvas? Thanks.
There are the factory IH pickups, which fit the 64, 76. I have a NOS in the box pickup for my 76 - I have not installed it yet, so am not sure if it would fit an 80. I believe it would, but the drive for it would be different, as a 76 drives the reel and canvass in a different manner from the 80 & 82. Width would not be a big deal, either would the mounting, as they mostly fasten to the sickle bar.
And then there are the factory ones to fit 80 & 82's.
There also were many aftermarket ones available. Lockwood-Innes made some, (which I have for my 82) and those will fit all of the abovementioned, as well as self - propelled machines, from the 91 all the way up to a 205. Subtle mounting / drive differences, that is about all. All that remember, anyway!
Best of luck.
Would this type of pickup from a 76 fit on an 82? Or would the widths be different between the models? It appears to bolt on the front of the head.
I will measure both combines tomorrow, and let you know. I think they are both 6 1/2 feet .
That is the attachment that i have for my 76 as well.
Sorry for the late reply - life happens.
Anyway, my 76 & 82 both are the same width at the sickle, so a unit from a 76 will fit. You will have to rig up a drive system for it.
Best of luck.
