weight of a Gleaner E
corn man
New User
This message is a reply to an archived post by SkyhighballoonMO on October 09, 2008 at 12:40:41.
The original subject was "Re: weight of a Gleaner E".
can you exchange engines from a Gleaner e 3 from a K Gleaner?
Engine and cradle should drop right in, you may have to change the rad and drive belt alignment. Ben
If I understand right you want to drop a GM250 from a K into a Gleaner EIII replacing the Allis 226? Like already said, if you have the entire engine cradle including radiator and it's from an early K, it should drop in. I'd consult a parts book to make sure the main drive belt pulley and front PTO that drives the unloading auger also are the same or if you have to swap some parts. Mike
