Re: N5 starting issues
Bob
03-27-2016 05:20:54
Does it begin to smoke right away when cranked, but not start?
If NOT, that would indicate fuel is draining back to the tank while it sits unused.
Check for any fuel system components, lines, and connections that may appear damp, or to which dust or chaff has stuck, indicating a small fuel leak. Check high-pressure fuel line connection and even injector leak-of lines and fittings.
Could be a lift pump (if used), or even a diesel pump or injector issue, as well. ANY place where air can enter will allow the drainback of fuel and delayed starting 'til the fuel system primes again.
