Fox chopper screens
Fordfarmer
I've had the screens that I got with the 4410 listed on craigslist for several months. Now, I have two guys asking about them. One guy is closer (same area code as me, at least), but doesn't know if the screens will fit his chopper...and neither do I... for sure. I think most Fox choppers use the same size screen, except for maybe some of the oldest ones. Is that right? These are about 20 1/2" wide.
If memory serves, the cutterhead is the same width on everything Fox from about 1960 onward. Your screens should fit a multitude of choppers.
They will fit every Fox ever made .
The mounting hardware/brackets on the different model harvesters is all that is different.
FYI, they will only work with knives that are 2 7/8 wide from backn of knife to cutting edge. Knives worn any thinner cannot be brought out to the screen. In case someone complains that they dont work once they have them.
Best of luck !
Back in the days when hammermills were used, they used to take out the worn screens and re-roll them so the other side could be used to grind more grain because the edges of the holes were sharp like the original. Just wondering if a chopper screen could be re-rolled to extend the life of it?
